WTD: KZJ78 parts
larsandjo
WTD: KZJ78 parts
Post by larsandjo »
Hey guys.
Just brought a new truck. 95" Kzj78 landcruiser.
Am after the following bits.
Stereo surround
Rear boot door cards Left and right
Center console lid/hinge setup?
Any aftermarket suspension items.
will add the the list as I find items I need to replace.
cheers.
Clint
Re: WTD: KZJ78 parts
Post by Clint »
I've got a couple of 40mm lift EFS rear springs looking for a home. Good condition, $120. Pretty sure the LJ71/KZJ78 are the same - can send dimensions to double check. Happy to freight at buyers expense.
Clint
027 212 4485
UZJ71 Landcruiser
KTM 640
tallsam66
Post by tallsam66 »
Where are you ????
larsandjo
Post by larsandjo »
Am In wellington. Cheers clint, If I post a pic of my truck, Are you able to tell me if it is lifted at all ? Springs are black... shocks are yellow. but it seems to be higher than I would of thought was factory
Clint
Post by Clint »
larsandjo wrote:Am In wellington. Cheers clint, If I post a pic of my truck, Are you able to tell me if it is lifted at all ?
Probably not, it's been a long time since mine was std... :lol: I'll measure up a spring for you tonight, then you could just unbolt one end of a shock & jack er up to unload one of yours & check the dimensions & free length.
Clint
UZJ71 Landcruiser
KTM 640
Clint
Post by Clint »
Sorry for the delay. but those EFS rear springs I have are 412mm free length, 150mm overall diameter, 16.6mm wire diameter & about 6 turns.
Clint
UZJ71 Landcruiser
KTM 640
Trundle
Post by Trundle »
We do 2 and 3" lift springs for the 78 series , they start at 500 for a full set of 4 dobis ,
We also have multiple shock options !
Can measure mine if you want I have a 2" OME lift
oldblue
Post by oldblue »
To get a correct measurement way don't you just measure from axle to bump stops,
