Running Boards? Side steps?
There are plates under the carpet that bolt through to them.
Mine where rusted i had to cut the bolts off from the top to get them off.
Removing running boards on my terrano HOW?!!
- travis2ninja
Re: Removing running boards on my terrano HOW?!!
Take both front seats out, remove plastic trim above the sills and lift up edges of carpet to access the bolts
Put the bolts back in the holes and find some nuts to hold them in
Have a bin handy for all the old coins and lolly wrappers you find under the carpet
I have a pair in good nick I took off my wd21 if you wanted to replace them? Or anyone else?
