As above
rear socket in boot and the centre console one are no goes however ciggy lighter goes have checked fuse under steering column and all is well
I suppose it has one of those pain the the arse inline fuses does it
Tim
12V Sockets Issue K96 Challenger
- jonossiksilvia
Re: 12V Sockets Issue K96 Challenger
Vehicles with multiple sockets usually have separate fuses in the main under dash fuse board. Might be labled power socket instead of cig
jonossiksilvia wrote:Vehicles with multiple sockets usually have separate fuses in the main under dash fuse board. Might be labled power socket instead of cig
Ive had a look at fuse board at drivers footwell and no other fuse that would represent them only the ciggy fuse.
Make sure the wire hasnt dropped of the back of the socket and the connector is in good condition.
churchill wrote:Make sure the wire hasnt dropped of the back of the socket and the connector is in good condition.
Been there done that.
Puzzling me.
Try this:
Directly opposite the fuse box under the dash is a white plastic panel with the fuse holder attached. You wont see the fuse until you open the little holder it is in. Has a red wire and blue and white wire running out of it.
Pain in the butt to get to as well. 15 amp job.
Hope it may help.
http://www.carcarekiosk.com/video/1997_ ... or/replace
Hope it may help.
JohnySWB wrote:Try this:
Hope it may help.
AWESOME you bloody legend you know how much that issue has bugged the hell out of me as having to use ciggy lighter for everything
What a pain in the butt it was though mines black just to make matters worst and tucked in behind a wire harness just to test my patience that wee bit more
Thanks heaps much appreciated
Tim
