Well it's that time again. ORE is going under the knife. The server is old, the site is old and it all needs to be upgraded.
server:/# uptime
15:34:58 up 1000 days, 20:48, 2 users, load average: 0.67, 0.82, 0.96
Some of you will appreciate the above statistic. The 1000 days shows the last time the ore server was rebooted!
I will try to keep the disruptions to a minimum while I upgrade the core stuff in ORE. I will most likely get the forums and vendor stuff upgraded and then work on upgrading the other bits and bolting them back on as things are completed.
as you were,
mike
