best safari/patrol veriation
For all Nissan related topics
93beachbasher
Post by 93beachbasher »
Hi
I like the safari and am going to look into getting one I currently have a Suzuki but I want to go play in the mud. Just want a bit of advise as to what I need to look for. what are the common problems
Ant
Re: best safari/patrol veriation
Post by Ant »
Rust..... will be somewhere between the front bumper and spare wheel holder :lol:
But more specifically under seats, firewall and sun roof, roof gutters. Apart from that they are mostly pretty tough. Any diesel will need a good service history especially turbo ones. Continuous heavy towing takes a bit of a toll on the highest gear (5th).
92 LWB Safari TD42
93beachbasher
which is the better motor the 4.2 or the 2.8 are the auto transmissions ok
timmay556
Post by timmay556 »
The 4.2 by FAR ---- How ever only if it is turbo'd.
Do not even try towing with a N/A TD42 unless its an empty trailer.
I've owned both, TD42 and TD42+T. The +T Shits on the N/A.
Also go the LWB for towing over the shorty.
mudy1
Post by mudy1 »
hi I am on my 4th swb and all but one were turbo;d, the one that was n/a td42 still went ok , towing the boat still did it all right just the hills got me down to 3rd, if it was a big hill then mabe 2nd, if you keep it up in the 3000rpm you will go every where. ps if you get a n/a then just get a turbo put in it. :D
Ant
Post by Ant »
Woh woh woh.......not 100% true.
4.2 is way better. Yes
Turbo is better. Yes.....but.....not necessary, I have n/a 4.2 and can tow another lwb 4.2 on a big trailer. Not the fastest in the world but sits quite happily at 90-100k on the main roads bit slow up hills but very comfortable towing heavy loads.
92 LWB Safari TD42
derk
Post by derk »
Ant wrote:Turbo is better. Yes.....but.....not necessary, I have n/a 4.2 and can tow another lwb 4.2 on a big trailer. Not the fastest in the world but sits quite happily at 90-100k on the main roads bit slow up hills but very comfortable towing heavy loads.
been there and done that if you haven't hit first gear your hills cant be very steep :D
datsunsafari
Post by datsunsafari »
go with the 4.2,the auto's good off road too imo :)
had to stop and put in first going up that hill in Napier from the coast up top the top of the headland :D
93beachbasher
mudy1 wrote:hi I am on my 4th swb and all but one were turbo;d, the one that was n/a td42 still went ok , towing the boat still did it all right just the hills got me down to 3rd, if it was a big hill then mabe 2nd, if you keep it up in the 3000rpm you will go every where. ps if you get a n/a then just get a turbo put in it. :D
How much would you expect to pay to turbo a 4.2 engine?
are the 2.8s rubbish?
tweake
Post by tweake »
2.8 are strong, bit of iffy injection pump but main fault is just low power.
with decent injection pump and turbo would it make reasonable power.
turbo 4.2, depends on if its factory or not.
factory turbo 4.2 is the strongest engine then silver top NA and then black top NA. there a list of the differences on patrol forum.
blacktop only handle light turbo.
what you pay depends on if its factory turbo or aftermarket turbo on which particular engine. for a real top end setup expect to pay a huge amount more.
Twodiffs
Post by Twodiffs »
timmay556 wrote:The 4.2 by FAR ---- How ever only if it is turbo'd.
Pffft!! :roll: .
To the op...a n/a TD42 will tow just fine, plenty of low down torque and don't try to treat it as a speed machine. I spent 5 years towing tandem trailers with premix and building materials around the hills of Akaroa and Banks Peninsula with a swb n/a. As said above a LWB won't rock around as a swb with a heavy load. I found 2nd or 3rd gear and with the engine at it's optimum torque range of between 1800 and 2200rpm it will pull anything all day long without overheating or any issues.
I have seen 2.8 Safari's that overheated or didn't cope at all with the roads coming out of LeBons Bay or Okains Bay...mind you some cars or back packer vans struggled as well.
Return to “Nissan”
