wanted pto winch for 70 series cruiser
Anyone got a pto winch for a 70 cruiser or a front bumper?
Re: wanted pto winch for 70 series cruiser
where are you
Palmerston north
- Still Unbroken
- Bush Crasher
What exactly are you after? Just the winch or complete with pto setup?
I have the whole setup but with nissan winch with a large steel cotton reel...
The whole set up as thats what il need right?
- Still Unbroken
- Bush Crasher
You sure will... Without knowing exact model, take the pto cover plate off and make sure the drive cog is in there first
most do but best to check...
See how you get on locally as while I have everything you need, it is a nissan winch and not as easy to remote freespool and still unsure about selling
Its for a swb bj70 and cheers man let md know haha theres one on trademe but of a different model
This one? http://www.trademe.co.nz/Browse/Listing ... =752720122
It wouldn't take much to make it fit - just driveshaft shortening and may need to modify d/s carrier mountings
Yes thats the one
muddy wrote:This one? http://www.trademe.co.nz/Browse/Listing ... =752720122
the 60 series shafts are longer than the 70 series so its only a matter of chopping a bit out and sleeving it with an old bit of tube and zapping it back together
derk wrote:the 60 series shafts are longer than the 70 series so its only a matter of chopping a bit out and sleeving it with an old bit of tube and zapping it back together
Be careful if you do that.. as been there done it and it'll shake ya fillings out if not reasonably balanced..
