WTB 2L-T mechanical injector pump
Ryanjury
Post by Ryanjury »
My injector pump is leaking and I wanted to source another one to play with before I take it apart and try and fix the seals. Or if I can source a good one I might just swap it out.
zukmeista
Re: WTB 2L-T mechanical injector pump
Post by zukmeista »
Due to the age of these motors replacing the seals would be the best plan of attack, as you can't tell how long the seals on another S/H pump will last and it would be a PITA if it started leaking not long after you replaced it... :roll: As well as the fact that these pumps are desirable to 2.8 hilux owners as they swap the boost compensators over when doing a turbo setup, so they tend to sell for a reasonable amount.
Ryanjury
Post by Ryanjury »
Yeah I plan to do the seals but I have no idea how to do it, I have done a bit of googling and want to try and do it on the truck.. Was hoping to get another pump and take that apart and figure out how to do it before tackling the one on my truck.
