Dumb dipstick Question
- Kiwithehunter
- Winch master
I just bought a safari, 1990 lwb auto. I'm not that experianced with autos, mine has done a few things to get me worried. It has usually preformed as it should(I think). But when it's cold it seems to change back and forth between top and overdrive. I've done the diagnostic thing that I found on here (thanks) and everything's alright. Is there anything else I should look at, a filter maybe? I've tried to check the fluid level but can't seem to get an accurate reading on the dipstick the oil is smeared about 2" above the hot line. Is this usually the case? Could overfilling be causing the problem?
How are you checking the fluid? Get the car up to temp, then put it from Park, thru reverse, N, D, 2,1 and back to park. Do this slowly so that the trans has time to change into the gear selected. Then turn off and check. Some of the Nissan autos suffered a dodgy valve that a $0.50 resistor from dick smith would fix. We used to do this quite often on Terranos esp.
Have you spoken to your local Nissan/Auto trans shop? They should be able to let you know pretty quickly.
- Kiwithehunter
- Winch master
- billyvanboheman
I always say there are no dumb questions, if you are afraid to ask questions for fear of others judging them everyone misses out
I for one learn a lot from this forum by reading peoples questions.
I’m not an auto fan but it's always handy to know this sort of stuff
Keep the questions coming I say
- billyvanboheman
DaveM wrote:The only dumb question I have heard is "why didn't I ask earlier, before I broke something"
Luckily it wasn't asked out loud, it was just in my head![]()
Nice one Dave, Just the Kiwi Male way
Old story about asking for directions and using the enclosed instructions.
Yeah Right
