I have 6 x 9's mounted in the front of the box's now that i have the fold out table on the rear doors. They make good speaker cabnets when empty
The box's are held in with three screws, so take about ten mins to pull out. Thing is you never have a need to as they don't restrict the use of the rears seats or cargo area. Different story with tha surf i guess, having the wide rear seat and all.
Reckon what ya need in a surf is complete fase floor that slides in over the top of the wheel arches right up to the rear of the ront seats in one complete unit. That way when your heading out, its a ten minute job for you grab the unit outa the shed, slide it in the back and anchor it down. If your want tie down points, put them on top of the false floor. Provided the unit is anchord down properly there's no reason why the tie down points couldn't be made strong enough. Hey, maybe a smaller/lower/different shaped chilly bin and you would be able to make use of the room in the surf and be able to sleep in it.
Quiet day at work, can you tell??
Not to be a prick, but have you thought about what happens when your on a muddy, boggy track, the rear loaded with gear, and you need to change tyres???
Just thinking of the mess that the now flat muddy wet tyre will make of you, the back of the truck, and what ever gear camping is in there when you hoist it up to nearly shoulder height and slide in, then it sits there as wet mud dribles of it every where..........
Haha, that worse case scenario mind
