I can't figure out what tells the relais to break the connection. Because: I also have another manual switch on the inside to wind the window up and down (installed after a thread here in about 2006). That switch works all the time, even when the relais has interupted the normal operation for the key or console switch.
Just one more time:
Can anyone explain this to me: The additional switch is wired straight into the original harness, which has its power interrupted by the relais - yet "my" switch still works??? Seems totally illogical.
How do I sort this out?
Any thoughts welcome!
