Rust Con
Rust Con
Looking for somethiung like this available in NZ:
http://www.superior-industries.com/products/aerosol-products/coatings/rust-con-500-rust-converter.html
Has to 'convert' / neutralize rust and act as a primer.
Also needs to be UV stable as I don't have an indoor workshop (well I do but it's full of fishing gear and other junk)
Planning on concentrating on smaller areas gradually, getting the rust sorted out then doing the primer/top coat in one big hit. So having a rust converter with a semi-permanent barrier would be fantastic.
Prefer liquid but spraycans would be OK just expensive.
Re: Rust Con
I got this and it looks very similar to the above link you provided
http://tradecatalogues.repco.co.nz/Repc ... ter/327634
Does the same thing.. etc..
Re: Rust Con
I just got some of this and it works brilliantly.
http://v2.nz.sparex.com/ItemDetails/Ite ... tCriteria=
- mudlva
Re: Rust Con
crc rust convert
all good
all good
- snotgoblin
Re: Rust Con
That CRC stuff looks remarkably similar to some Loctite stuff I used to have.
Worked very well at attacking the rust on my old SJ413..
Re: Rust Con
I find the best way to convert rust is with a grinder
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
(027 788 1046)
Re: Rust Con
The WEHI wrote:I find the best way to convert rust is with a grinder
Re: Rust Con
Thanks, both those products look like they will do the job. I had some spray on stuff from Supercheap which left a coating but it washed off, was rubbish. Good to have some recommendations.
Yes obviously the bulk of it will be removed first. Want to make sure I kill it off properly for good.
Re: Rust Con
I used a spray paint style converter that acted as a primer/undercoat when doing some rust repairs and worked awesomely i will look for it in the garage after work
(027 788 1046)
(027 788 1046)
Re: Rust Con
Here's what i used to use when painting rusty marine engine blocks, worked a treat and was one of the cheapest too.
http://www.bunnings.co.nz/tergo-rust-co ... _p00694563
Re: Rust Con
sibainmud wrote:Here's what i used to use when painting rusty marine engine blocks, worked a treat and was one of the cheapest too.
Mitre 10 sells this too, it is awesome stuff.
Ph 0212078472
Ph 0212078472
Re: Rust Con
I just got some crc stuff in weekend and ripco and was cheaper.. 20% rade card and was about $40 from memory..
Re: Rust Con
POR15
Nothing beats this stuff. It's not cheap but you can be confident it will work.
Re: Rust Con
kiwipete wrote:sibainmud wrote:Here's what i used to use when painting rusty marine engine blocks, worked a treat and was one of the cheapest too.
Thanks, I am pretty sure this is what my mate recommended but I forgot what it was called. Will give this a try.
Anyone used it and left it out in the rain?
smurf182 wrote:POR15
Yeah I have read nothing but good things about the POR15 system.
Do they do a rust con though? I wasn't aware of that, only their primers & topcoats.
I would use this on my toys, but there is no supplier in Palmy afaik
- Driver/Navigator
Re: Rust Con
cbfb wrote:kiwipete wrote:sibainmud wrote:Here's what i used to use when painting rusty marine engine blocks, worked a treat and was one of the cheapest too.
Anyone used it and left it out in the rain?smurf182 wrote:POR15
I used the Bunnings stuff on my RRC, it might be ok in the rain after it has fully cured but it is water soluble so mine ran a bit (in the driveway with no doors on). Painted over it with one of the white knight epoxy enamels and it seems to be ok, only did it a few months ago though. Dont try and weld over it/near it though, the smoke is pretty toxic.
Re: Rust Con
Got the CRC stuff in the end, will give it a crack at the weekend
