I did the holden v6 conversion a year or 2 ago but the motor ran rough as and was overfuelling (parked it up)
1990 v6 vn motor, was a runner in a car before i removed it.
it starts up but runs rough as and black smoke.
-have checked the injectors and they are good.
-rulled out fuel pump as i had my mates pump and fuel hooked up and still the same.
-the car runs idols perfect when the fuel pump is un hooked (no power)? i know it dosent sound right but as soon as you turn the pump on it starts farting around again.
-you need the pump to start it but once its started and you turn the pump off it purs away??
-also there is not much flow out the return line?
could this be down to the fuel regulator
any help appreciated
Brendon
