Wanted: broken / bent rear axle shafts
kernels
Post by kernels »
Hi guys,
I'm after a couple of broken / bent / working rear axle shafts for a non 4wd related project, preferably around 30mm diameter and in the general Auckland area if anybody can help.
Willing to pay double scrap metal price + collect, or a box of whatever you drink.
mudlva
Re: Wanted: broken / bent rear axle shafts
Post by mudlva »
You after diff axle half shafts or drive shafts
kernels
Post by kernels »
mudlva wrote:You after diff axle half shafts or drive shafts
The solid steel shafts that connect the diff head with the rear wheels. I had some Vitara ones with a twist in them, but scrapped them at the time unfortunately.
Mehrts
Post by Mehrts »
Just out of interest, what are you thinking of doing with them?
Toyhatsu Bitsalux
mudlva
Post by mudlva »
I have a set of 60s l/c half shafts here. Still in complete diff assembly which i have not yet stripped. Will be available around mid september. $40 if keen
kernels
Post by kernels »
Mehrts wrote:Just out of interest, what are you thinking of doing with them?
I've been doing a bit of blacksmithing lately as a hobby, axles are made of fairly nice medium carbon steel, and I'm wanting to forge some throwing axes. That's why around 30mm or so diameter would be awesome.
kernels
Post by kernels »
mudlva wrote:I have a set of 60s l/c half shafts here. Still in complete diff assembly which i have not yet stripped. Will be available around mid september. $40 if keen
Thanks mudlva, I will keep my eyes open, but if I have no luck will grab them off you. Let me know what diameter they are if you get a chance to pull one.
H
churchill
Post by churchill »
You can buy 4130/4340 and other similar steels by the meter from 'steel and tube'
kernels
Post by kernels »
churchill wrote:You can buy 4130/4340 and other similar steels by the meter from 'steel and tube'
Hi mate, long time no hear. I will give them a call tomorrow, didn't realize they did anything other than mild steel!
