Turbo bits for 3L
benj416
Turbo bits for 3L
Post by benj416 »
Hey guys anyone got the bits to turbo a 3L lieing around that they would part with as I'm in the process of turbo ing mine
Thanks ben
rxsmiddy
Re: Turbo bits for 3L
Post by rxsmiddy »
see my bits in this section mate
benj416
Post by benj416 »
Bump
benj416
Post by benj416 »
Bump
derk
Post by derk »
which bits do you want mate
benj416
Post by benj416 »
Exalust Manifold
Inlet manifold
Cross over pipes
A ct20 doesn't really matter what condish as I'm going to get it rebuild anyway
Think that's all
bryandc3
Post by bryandc3 »
might be able to help, got all those bits off my 2lte, how much were you looking at spending?
Smurf
Post by Smurf »
bryandc3 wrote:might be able to help, got all those bits off my 2lte, how much were you looking at spending?
Aren't you going to drop the turbo onto your replacement 3L?
bryandc3
Re: Turbo bits for 3l
Post by bryandc3 »
Na to do it properly would mean decreasing the compression and getting it dump tuned. So basically can't be stuffed
tweake
Post by tweake »
bryandc3 wrote:Na to do it properly would mean decreasing the compression and getting it dump tuned. So basically can't be stuffed
??? no need to change compression. not sure what you mean by dump tuned but wind up the fuel a tad will do the job.
Smurf
Post by Smurf »
Dump tuned??
Just a case of swapping manifolds, oil cooler plate, run a turbo drain, hook up water lines for turbo if it has them, and fit the boost compensator from turbo injector pump to the 3L Pump. and Bobs your aunties second cousin twice removed.
bryandc3
Post by bryandc3 »
My bad phone doesn't like dyno n :mrgreen: ot dump hah
benj416
Post by benj416 »
Still looking
dan.c
Post by dan.c »
benj416
Post by benj416 »
Dam it I just missed that auction I would have so brought that :/
benj416
Post by benj416 »
Bump
Crash bandicoot
Post by Crash bandicoot »
I saw a complete 1kz turbo engine in an upside down surf this weekend just passed...bit of a drive to get to it though,
