january 6th & 7th
niblik
january 6th & 7th
Post by niblik »
bled brakes on rusty and got battery charged for jaunt up the mak..
gave young rokpup a drive in rusty too... he'll get hooked on a 40.. :thumleft: dont worry rokhound, pretty soon he'll be like ole nibby here... a bit :cyclops: (one eyed.. :lol: )
good days wheeling, found large leak in diesel fuel line when hookin up rusty to tow home, but all good.. :shock:
starter motor on goldmember (my daily driver) died.. :(
so looks like sunday is already planned out for me.. :roll:
NJV6
Post by NJV6 »
Got the head back on the Pajero and all bits - went to fire it up and blowed if the bloody thing will go.
Cylinders 3 and 4 are not firing, must be the injectors, but I know absolutely nothing about injectors except there are lots of little bits in there.
Injectors 3 and 4 needed to be dismantled to get out of the head so I suspect I didn't get it right putting them back together...... :roll:
I'm going to sulk now.
wjw
Post by wjw »
Well, lets see, looked at a house yesterday, split the sump on the Prado outside Mikes place when I dropped it into Low 1st from Low 2nd. Engine breaking on the auto works now ;) .
Made an offer on a house today and started planning my garage build....
Who knew Prados could fly?
mud_slinger
Post by mud_slinger »
went to waiau for the weekend, went down the conway river from lyford down to state highway 1 was a good drive down river bed, somehow i managed to bend the shackles on my rear leaves,and the rear crank seal decided to give up and a bolt managed to come loose and fall out of my brake calliper so drivin home wit 1 bolt aint nice :shock: my head stil hurts from the copious amounts of alcohol consumed. 2 of us went thru 4 18 packs of speights :lol:
needs more curry
0272593533
wopass
;-p
Post by wopass »
worked saturday, and spent last night and most of thismorning putting my fuel tank back into the missile after repairing the leaks it had......
sneezed about a million times, hayfever suxorzz :evil:
and planning the new drivers seat bracket for new seat....when i find one 8)
wjw
Post by wjw »
wjw wrote:Made an offer on a house today and started planning my garage build....
Offer was accepted so providing the reports etc are good we own a house!!!
:shock: :shock: only took 4 hours! man that beats england...
Moriarty
Post by Moriarty »
NEW ZEALAND beats England.
Aussie beat England, 5 five nil
My darling is English, and she aint never going back except to remind herself that NZ is truly Godzone.
De-Ranged
Post by De-Ranged »
Hmmm
stirpped enough steel box section off an old apple picker to make the chassi and drawbar for a new tandom trailer .... and made the lower half of a tipping tandom trailer still working on fitting brakes
Built up a new (second hand) diff for Mudda's truck a set or 5.29 gears (ex lemon) that I'd cryo'ed stuck onto a slippery pack dropped into a standard housing.... all ready to go now :D
And built up 6 new traffic sign stands... for work
And now I'm about to go weld up Muddas floor to the new transmission tunnel 8)
Hey Bill congrads man :D
Cheers Reece
mercutio
Post by mercutio »
got a new battery for my other little project got it running and took it for a little drive
4wdnuts
Post by 4wdnuts »
this was done over the previous week but most of it wrapped up over the weekend. added smaller bars around head lights and changed the mounts. also added two aerial mounts and screw in rope holder at the top.
then installed the uhf radio under the stereo and installed the charging cradle for the handheld vhf radio
then knocked up a tool box to fit in between the wheel arches.
also went down for a bbq at ashworth beach. went floundering and caught a few. and replaced a broken front wheel stud and tightened both front wheel bearings. also had to replace shackle bushes.
hosehustler
Post by hosehustler »
I finished up the front end of the truck... shocks all insatalled, front bump stops finished, happy now with soring height after pinching some bits off the OME 50mm+ springs i had, spings installed and happy with the result, would like to post some pics but will have to wait till i get back to work for the digicam :lol:
all up left to do ...finish powersteer pump, finish exhaust...nearly there :P
I hate signatures
LOLYF
Post by LOLYF »
Spent the day putting the interior back in the lux.
nothing like 1000 watts to keep you amused when 4 wheeling.
And a tv/dvd for when im really bored!
I need a new steering wheel.
Made some new speaker pods for the doors.
mudzilla
Post by mudzilla »
Coming along..But how long will the battery last running 1000w and DVD with no engine ?..Have you see HiLux dragster on this forum? :D
LOLYF
Post by LOLYF »
Ha ha batterys on the charger now! :D
mike
Last minute Mike
Post by mike »
Its gonna be interesting seeing the new mods tim. You can buy little plastic stools from "The Plastic Box" in riccarton, I have feeling your going to need them for yourself and passengers getting in your truck. You will probably need to tie a string to yours so you can pull it up afterwards :lol:
I scrubbed and cleaned the road in front of the neighbours after the latest supra conversion turned up - wjw's 2JZ. Seems there is still some finishing to do :wink:
The recovery service turned up soon after to wisk away the project but I got the photo scoop of its first break down :lol: :lol:
That was sat, and today I mountain biked up the worsley spur track to work off some of this xmas pudding (got a lot of riding to do :roll: ).
Watched a grey swb LC with mudzillas on it with some young guys in it winch the farmers fence over flat trying to get up a certain bit of the track(winch cable was on 45 degree angle - was never going to work for where they were, the weight of the vehicle and using just a fence post). Bit of common sense wouldnt have gone astray here :roll: Obviously if the fence starts to lay over you should stop instead of carrying on and ripping the post completely out of the ground, not cool :thumbdown: and to top it all off - all in front of a mountain biker. If anyone knows these guys educate them please LP UA4161 8)
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
You could build a small epia mini computer to go with that as well and store your mp3's on it and hook it up to your sound system....and add in a GPS reciever, mapping software and webcams....
eg http://www.trademe.co.nz/Computers/Comp ... 246451.htm
callum007
Post by callum007 »
repalced dizzy on blizzard. runs like bag of shit.. yes the firing order is right. I cant find the timing light to check it.. I recon i might just get the engine blueprinted.. might go better..
starting to get some flex...
got a bit of drama with steering knuckle hitting shock sometimes.. cant hit at full lock but im picking its the munted bearings letting the wheels wobble..
and i bought a Grand cherokee... i needed a shopping trolley
matwelli
Post by matwelli »
installed the most important piece of off-roading equipment there is....
After buying them 6 months ago, I finally put the http://www.offroadexpress.co.nz stickers on 8)
Plus took the kids out along the meremere track (follows the power pylons to the patea dam), nice little drive paupa/clay track. Kids really enjoyed it :D
Mathew - 021 441 043
Petemcc
Post by Petemcc »
hey lolyf i think i have the same head unit as you and have it hooked up to a screen for the dvd, how did you get tv?
just realised i should have really pm'ed you. give me a pm if you read this
Cheers Pete
Rotazuk
Post by Rotazuk »
Well since the zuk is not running too well i took to the loom with some cutters and started to wire in a new ecu . Lost the wiring diagram I had when I installed the first one so moved on to other stuff . Decided since the zuk was not going I had better fix the brakes as they were seized ( you strugled to move it in high ratio :lol: ) as you could not push it around the garage .
Took 5 hours to get all the pistons out of the caliper :( . pump one out , disassemble the caliper , clean up the piston that was out . put it back in reassemble the caliper , block off that piston and do the whole thing again . Grr there is four pistons . Done one side and left the other side for another day .
Moved on to something else that was more fun . Mounting up the super charger to the 1600 suzuki engine . Its a good fit .
Then finsihed off the tow hook mounts for the front of my cousins club truck ( suzuki vitara ) .
Keep finding more work to do before the body can go back on to the chassis :( . Still its a new year so have plenty of time .
Chris
matwelli
Post by matwelli »
That supercharger looks sweet , I guess its of a 4age ?
spanky
Post by spanky »
went and played up the bush, a mate took the datsun i bought up and i took scudo, put some pics in album, tryed to put video on but cant get it to play and will try again later. how long should it take to load video 1 min long have grunty computer but slow dial up out here cheers
vaughan
BrentC
Post by BrentC »
4wdnuts wrote:this was done over the previous week but most of it wrapped up over the weekend.
Tony's bars work well too :lol: except for those tight spots on the 42nd Traverse
Hung up tight against the side walls - he couldn't go forward or back
wjw
Post by wjw »
I like the 'Recovery' sticker... maybe he should change it
Rollux
Post by Rollux »
wjw wrote:I like the 'Recovery' sticker... maybe he should change it
to "RECOVERED" :lol:
1989 LN61 Hilux Surf
K&N Filter
Skyline Intercooler
2.5" Exhaust from Turbo
mroffroader
Post by mroffroader »
bloody wicked rotazuk!!!!!!!!!!!!!! 8) 8) 8) 8)
