6th-7th September
6th-7th September
brought new radiator fan, fitted pulled broken blade bits out of the shroud , then did bugger it moment pulled radiator out to get it serviced on monday
Re: 6th-7th September
Got the SJ out this morning to have a little play and see what else needs to be done - which appears to be heaps
Will have to do a RUF I think
^^^ Those front guards look a bit different, are they f/glass ones? Looks good. Well I put my jigsaw puzzle back together today, two manifolds and a turbo all on the same side = absolute c##t to work on
Got a mean whistle now though, suspect a boost leak somewhere. Was only getting about 5psi so tweaked the hoseclamps up some more and now got 9psi (normally get 11) so waiting till it cools down then I'll check all bolts etc.
zukmeista wrote:^^^ Those front guards look a bit different, are they f/glass ones? Looks good.
Cheers, they are steel pajero guards, cut the flares out and stitched them in, wanted a bit of a different look as the standard guards were rusted out
Replaced the wipers. Needed all the coffee I could find.
- Crash bandicoot
A little while ago i decided to take care of the mistrals sagging suspension, she had a bit of a lean to one side, discovered a twisted torsion rod.
A quick search of ebay.co.uk 2 weeks wait and 280 british pound later and she sits 3 inches higher now.
Finally got around to putting dual battery system in the Terrano. So then thought i might as well hook some lights up on the awning.
Went for a run up Rallywoods yesterday with a few people off her, Lax2wlg, 1kzsurf, Full throttle and a bunch of others.
Great day, only minor panel damage. Couple of other trucks had CV escaping problems.
Just finished water blasting the 100kg of mud off the truck.....
Good times up there, Team Terrano was well represented.
Torsion bar?
You got new OEM torsion bars? Where from? Do you get to choose diameter (spring rate)??
Pics dont work.
Crash bandicoot wrote:A little while ago i decided to take care of the mistrals sagging suspension, she had a bit of a lean to one side, discovered a twisted torsion rod.
A quick search of ebay.co.uk 2 weeks wait and 280 british pound later and she sits 3 inches higher now.![]()
Torsion bar?
Pics dont work.
- Crash bandicoot
my sister n law is a pom'
Brought a complete jimnybits lift kit off ebay from a wrecked terrano 2, got it steam cleaned and she managed to bring it back with her
rear coils, torsion bars, UCA's eccentric bushes for front diff.
Just paid for the extra weight at terminal check in.
All ready had longer RAW shocks.
Pulled out the Hilux radiator after having an encounter with a branch last weekend... Now to find another one.
Toyhatsu Bitsalux
Had no front driveshaft for 2 weeks as transfer got stuck in 4wd so had a look through FSM today and managed to get the vacuum engagement system working properly so now have 4wd again, might have to 'test' it to make sure it works...
Mehrts wrote:Pulled out the Hilux radiator after having an encounter with a branch last weekend... Now to find another one.
Hi,
Same guy that had the gearbox has a radiator there as well, from memory the core wasn't great but I could take it to the radiator shop in town and have it pressure tested if you were interested?
Well I have only been talking about fitting twin snorkel's to my Safari for about 5 - 6 months now, so after having all the bits for 4 - 5 months thought I should do something about fitting them...
Shopping list was 3 meters of 3 inch stainless steel, two 45 degree silicone bends, 10000 3 inch clamps, one 3 inch to 2.5 inch reducer and some sealant...
Then there was the small matter of having someone with a Tig welder I could borrow, well the first Tig welder I borrowed didn't work very well, so it was plan B - called a mate (Thanks Mike S) and he came out an helped with his Tig welder...
Happy with the end result, just have to but two snorkel ram's now... I have one but unsure where that is.. (the one in the photo is from a Ford ...)
Fitted my new auto trans solenoids. The truck now shifts beautifully and has all gears. It's the first time I have driven it with a fully functional box. It's like a new car.
Really should have taken a photo of that stick it was pathetic
- stovanovich
Pulled out the long busted air vents in the terrano and replaced them with Bodykit grille. Came out looking pretty fancy and the grille is angled so air flow still flows in right direction.
Te Rino
"Hubs In, Caps Off"
"Hubs In, Caps Off"
Done a Sua conversion on my scabby FJ40 and trial fitted a power steer rack and pinion steering setup, looks like it will work so I'll engineer proper brackets and shafts now.
