After some 3" ID coils.
As per title. I need to get my mits on some 3" internal diameter coils. I need 2 x 250 lb x 14" and 2 x 300lb x 12" units. Anyone know where these can be purchased in NZ please?
Mr Revhead
Re: After some 3" ID coils.
Tried Autolign? Stocks? Chamberlain springs? Bellamy and East?
Yep
The standard ones that are manufactured in NZ are not up to spec with the type of wire used. As this material is a lower grade than that used by specialist overseas outfits, there are more turns required per lift of the coil. This results in you not being able to use all the shock length as the springs bottom out before the shock does.
Cheers Warren,
Can I get cheeky and ask if there is any discount to be offered on listed prices?
And do you have all sizes in stock?
(Order will more than likely come your way anyway)
