Nissan VH45 runners wanted.
Checkerhead
Post by Checkerhead »
OK not 4wd parts but hey...
I need the four corner runners that go between the block and the plenum, that the injectors mount into.
They have two different types. Some have about a 30mm odd diameter rubber that mounts the injector. Some use a smaller diameter rubber (maybe 20mm). I need the ones that use the smaller rubber.
So who has some VH45 parts? or knows someone?
Cheers.
Arron.
Crash bandicoot
Re: Nissan VH45 runners wanted.
Post by Crash bandicoot »
what is the engine serial or if you know what model and year the engine came from or is in?
Checkerhead
Good question.
The engine I have will have the wrong runners associated with it. So serial probably wont help.
It's currently sitting in a Safari so that won't help.
They are originally in Nissan Infinity's (Q45) from 1990 to 1996.
I believe that I am after runners from the last few years, but I really do not know for sure.
I will do some research.
Crash bandicoot
well we can narrow it down some more the timing chain guide is it plastic/nylon or metal?
Does it have Vairable timing or not
is the alternator top mounted or not?
1990 to 93 had equal length runners and twin circle intake ports
94/95 had oval intake ports and revised injectors.
96 had no VTC
Checkerhead
Well you know your stuff. (not the first time you have proved it of course)
Am told it has a metal timing chain guide. But I don't know if that is standard or has been replaced due to the known weakness.
It does have VTC and has/had twin circle equal length runners.
Based on what you have said I guess I need the 94/95 runners. That is assuming the 90-93 runners are interchangeable with the 94/95, except that the injector mounting is different?
Checkerhead
Will try to find time on the weekend to pull it apart a bit and get photos of what I need.
Oh forgot, no idea where Alt was originally mounted. (I bought a part done project)
Arron.
Checkerhead
Just pulled them off.
Can confirm I need the 94/95 runners with the ovel port.
I currently have the 90/93 siamese runners.
Will try to uplaod pics tonight.
Arron.
Checkerhead
Thought I had a lead but it has dead-ended.
Does anyone know anyone who is using/has used VH45 engines that I w=could hit up to see if they have parts?
Any help or leads much appreciated.
bombaybasher
Post by bombaybasher »
I've blown up a couple , got oval and Siamese runners I'm pretty sure I didn't scrap them , they at my brothers place under the hoarding pile , I'll check it out this weekend , keep your eye on this forum , I should have the complete intake manifolds as well
Checkerhead
Bro! I would be stoked if you have some!
Will keep an eye on this but flick me a text on 027 278 2556 if you want if you have any.
Cheers.
Arron.
Checkerhead
And if you do have them, bring them with you and dream up a price (I'm a poor student now days but am obviously willing to pay)
bombaybasher
Will do , be looking on sat
bombaybasher
Ok so I found the intake manifolds , heads and blocks but no runners , there is a lot crap to dig through and it looks promising so I'm looking again on sunday
Checkerhead
Thanks bro. Fingers crossed.
bombaybasher
bad news after an hour or so could only find one runner and its damaged , sorry dude.
Checkerhead
Sweet as. Thanks for trying. Much appreciated.
