Got a Mitsi J Top with the above engine and it wont start which has me baffled.
Seems to have fuel but no spark, took the lead off the coil and checked it against the engine.
This is third time it has happened, last two times after lots of cranking and fiddling around it fired up and then would run and start again no problem. Was running fine a week ago.
One possible common factor is prior to it not stating, the battery had been disconnected for over a week.
Is there something that needs to be done to get it going after the battery being disconnected, or any other thoughts on what might be the problem, not very familiar with electronic and efi system.
Very frustrating when it was going so well before
Tim
