Toyota Hilux Axle and CV Options For Sale
From lockers to air deflaters, if it has to do with wheels tires or axles, you can find it in here.
Moderator: Vendors
4wdstuff
Post by 4wdstuff »
Hi,
If you are looking for Hilux CV and Axle Options have a look below.
Trail-Gear Toyota Front 27 Spline 4340 Chromoly Birfields (CV's) $140 each
Trail-Gear Toyota Front 27 Spline 4340 Chromoly Birfield and Axle Kits $350/ set
Longfield 27 Spline CV's $300 each
Trail Gear Dirty 30's - 30 Spline Birfield (CV)/Axle Kit $850 / set
Trail Gear Dirty 30's +3" - 30 Spline Birfield (CV)/Axle Kit $850 / set these have an extra 3" added to the short side axle if you want to make your front axle a bit wider.
Longfield 30 Spline SuperSets Axles and CV's $1000 These are US made, the newer Trail Gear ones I believe are not made in the US. Only one left
Trail Gear Longfield 30 Spline SuperSets Axles and CV's $850 the Trail Gear ones I believe are not made in the US.
Trail Gear Longfield 30 Spline SuperSets Axles and CV's with Hub Gears or Creeper Drive Flange Kit $1000 Trail Gear ones I believe are not made in the US.
Longfield Hub Gears $200 for a pair
Longfield Drive Flange Kit w/Dowel Pins, Drill Bit and Dust Shield $275 for a pair
Toyota Creeper Drive Flange Kit w/Dowel Pins, Drill Bit and Dust Shield $210 for a pair
Just need to add on post.
PM me if interested
Cheers Tim
http://www.4wdstuff.co.nz
4wdstuff
Re: Toyota Hilux Axle and CV Options For Sale
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
4X4LUX
Post by 4X4LUX »
hey mate can you get trail gear long slip drive shafts? cheers Adam
4wdstuff
Post by 4wdstuff »
Hi Adam,
Yes got a couple coming in my next shipment, hopefully be here in about 4 weeks barring any holdups.
Tim
womble
Stropper
Post by womble »
Hi does anyone know much about toyota surf add actuator my one is not working have moved the hose on the add solenoids so the vacuum goes the other way but did not engage . have look at the add actuator it can hold a vacuum and all so taken it off and moving fine.
now for the other one when i push to button to engage 4wd only have vacuum on one side of the add solenoids then when push button to go out of 4wd the vacuum has not moved to the other side . Have done some tests on mates surf but do not know were to go now
thanks andrew
4wdstuff
Post by 4wdstuff »
Bump
PM me if interested
Tim
Return to “Axles Tyres and Wheels”
