Suspension lift r50
For all Nissan related topics
Gcdogg
Suspension lift r50
Post by Gcdogg »
Anyone lifted a r50 terrano before looking into doing mine extra 2" or so .
Is there a spring out of another vehicles that will fit in and give it a raise or should I be looking into buying new . Heard that jeep springs work if the top coil is cut off but unsure on this and what model from.
Crash bandicoot
Re: Suspension lift r50
Post by Crash bandicoot »
Did you try the search function......?
Gcdogg
Post by Gcdogg »
Yes indeed I did thanks . Nothing has answered my question that I have asked here from what I can find . I'm sure this isn't going to hurt anyone
Crash bandicoot
you will be needing 50mm polymer/high density/aluminium spacers to space the macpherson strut away from its seat in the inner gaurd and some jeep grand cherokee springs to replace the existing rears(if it is a H233b axle)
then need to get longer shocks, the RAW ones come factory two inches longer over OEM part numbers
chop
Post by chop »
There is a guy in Albany that has some springs, I got mine off him for 60, are they the same set up as a wd21?
Built not brought
Return to “Nissan”
