2004 mazda bounty lift kit
brakes-shocks-lockers-etc
wildplumdx
Post by wildplumdx »
just got me a 2004 mazda bounty 4wd to replace the old 96 l200 4wd, hopefully its a upgrade off road.... well they come bog standard hell of a low and was looking at lift kits and came across this... looks pretty good, what do you guys recommended ? http://www.ebay.com.au/itm/Mazda-bravo- ... 27ec1296d5
zukmeista
Re: 2004 mazda bounty lift kit
Post by zukmeista »
Not sure but doubt those arms would pass a wof without some sort of structural testing to make sure they're safe from memory. Due to the fact that they allow more droop travel a diff drop would be a good idea otherwise you may exceed the max working angle of the c.v.'s. The shackles are nothing fancy wouldn't cost much to get a local fabricator to make some for you.
