I'm having weird starting issues and can finally not get it to start. Just clicking. I poked around and looked at the starter and noticed a wire that looks like it should be going somewhere, as the other one that comes from the connector Black/Pink or Red can't tell bolts to the stop of the starter. The yellow wire/ with green seems to be disconnected and I am thinking this may be my culprit.
Can anyone help me identify where I should have this thing hooked up to? The connector is on a WD21 automatic that was converted to manual and with the TD27.. I'm getting so annoyed trying to figure this out on my own and was hoping you guys could come to the rescue. The starting issue was intermittent so it would make sense that this wire has some significance.. Where should it go?
Thank you all!
Connector in question.. Located on passenger side behind the battery. Two prong connector with two wires Black /Pink and Yellow / Green:
Black / Pink and how it connects to the top portion of the starter.:
And finally the wire in question Yellow/ Green :
The million dollar question is where in the hell should this thing be connected?!
Thanks in advance guys!
