My 96 Challenger is getting a bit Sluggish on the hills and is getting notibly worse, Ive just done the Injectors/Glow Plugs/ had the Valves/Tappets checked etc by the pros. Have just serviced also and nothing seems to have made much of a difference? Fuel pump has been replaced (some time ago)
I blanked off the EGR Valve a few years ago (was recommended too..) made no difference, could this be the cause?
Transmission has been serviced and was told is in excellent condition.
Should I be looking towards the Exhaust perhaps choking the engine? Turbo issue?
It runs like a dream on the flat, idles perfectly, blows ZERO smoke at all.
Im at a loss, any suggestions or recommendations to check/look into?
4M40 Getting Sluggish
Re: 4M40 Getting Sluggish
Gidday,
Dirty Air flow sensor? Family member had a TD27-T in a 96 Terrano that suffered the same... was good on the flat, but as soon as it came anywhere near a slight incline it was a gutless as anything - some hills you could have your foot flat to the floor and it wouldn't get over 70 kms.
Quick clean of the air flow sensor and it was like a rocket ship in comparison.
Could be worth checking.
Jay
Jay
Check the rubber hose to the boost compensator on top of the fuel pump. Check both ends, and make sure there's no sooty oily crap blocking the nipple on the turbo end.
How hard can it be?
Stretched timing chain most of the time on these old donks do we have a sweep stakes ?
Its looking that way mate,
I can see it being a busy week comming up, thanks guys for the help too! Much appreciated, gives me somewhere to start!
Cheers!
Cheers!
