where to get air con lines fixed in southland
olielux
Post by olielux »
took my 80 out for a drive today and in a radical turn of events including my mate deciding not to tell me about the branch leaning over the track on his side that I couldn't seen, it came through just below the headlights and took out an air conditioning line, power steering ling cam off the reservoir, the bottom of the plastic cover over the timing belt and also the indicator below the headlight
Also the radiator might have been pinched but I will investigate that better tomorrow
Yup not ideal but shit happens
Anyway I need to find somewhere that can fix the metal air conditioning line and recharge the system if anyone knows of someone that can do it and is resonably priced that would be great also if you can help with any of the other parts I need please let me know
Thanks Oliver
NJV6
Re: where to get air con lines fixed in southland
Post by NJV6 »
Where are you in Southland?
Get your parts needed from a wrecker and then air con - in Gore I use Michael Kelly Auto and invercargill I used AJ auto but there are plenty of others.
olielux
Post by olielux »
hi mate Im in winton, would you know of any wreckers wrecking an 80 series
My mates wrecking one but its a petrol so cant get all the parts off him
Thanks
Big
Post by Big »
what parts are you after exactly?
olielux
Post by olielux »
after looking at it this morning im going to need a new timing belt cover, air conditioning line that goes from under the headlight and has a joiner along the guard behind the battery and a new indicator.
Am still inspecting damage so could need more but radiator doesn't seem to be leaking
bigstu
Post by bigstu »
Give marty a call mj auto electrical he also aircon man does all trucks and loaders at work hes based in winton
https://m.facebook.com/profile.php?id=1 ... 94723&_rdr
olielux
Post by olielux »
do you know if he would be able to get me the air con line I need
bigstu
Post by bigstu »
Ring him and see
Return to “Toyota”
