After some help td27
Austerrano
- Stropper
Hi, I've searched everywhere and unable to find out some info on some hoses.there's a solonoid near the brake booster and a line coming out could you tell me where it goes? It's vacume unsure if it goes to the top of the injector pump or elsewhere. Is a td27t 90 mod terrano.
- Crash bandicoot
Re: After some help td27
egr valve mosdt like, but will have to ask Lax' mine TD27 is a 98 mistral and the actuator for the egr was on the left hand gaurd.
Austerrano
- Stropper
It's a small valve behind the booster on the firewall, has two wires to it and a vac line in and out.ive just done the egt removal, inter cooler and taken the inlet off and gave it a clean out, but I removed it all then went back to work for a month so forgot where they went
There is one small hose goes to a diaphragm on the injector pump, for fast idle when the aircon kicks in...
Austerrano
- Stropper
Thanks for the replies, would it be a vacum to the diaphram or boost?i have two hoses left I'm unsure off. One that would have came from the original cross over pipe also the one from the solonoid switch on the firewall. Thanks for the help appreciated.
