Hey has anyone used those SCR320 turbos? and if so what sort of boost are they running?
anyone using any other turbos?
what boost are you running in the td42s?
TD42 turbos
Re: TD42 turbos
I got a big garrett only does 10lbs
Re: TD42 turbos
oh yea what sort of garrett? 10lbs as in 10psi?
Re: TD42 turbos
haha, typo what I am famous for
no real clue what type, it works gets me up the Bombay hills at 90+ kph ,on 33" s
my first turbo fitment
viewtopic.php?f=25&t=26215&start=120
Re: TD42 turbos
I had the scr fitted recently
Run 10psi, im told the turbos will do about 15psi.
Re: TD42 turbos
that first turbo did go up to 20 psi before the oil seal blew
- crazyclark31
Re: TD42 turbos
Tdo5. The small 16g wheel version works well with the standard pump. Set up at 15psi these make the td42 come alive.
Re: TD42 turbos
man its a hard thin to decide people say different things dont know what to fit.
Re: TD42 turbos
go by crazy's post bud, same words as on patrol forum
- gary_in_nz
Re: TD42 turbos
crazyclark31 wrote:Tdo5. The small 16g wheel version works well with the standard pump. Set up at 15psi these make the td42 come alive.
i second or 3rd that i run the same setup same boost and she does come alive.
Re: TD42 turbos
cheers guys ive heard of a few people run those scr320 just checking other options. pitty theres none in the country atm. story of my life
Re: TD42 turbos
lol what your going to pay for something..... where are you son..... would like a talk with you
