So theres a lot of ways to do this, be it professional equipment or home made, but if you've ever use this method can you tell me, compared to pressure bleeding included the normal 2-man manual bleeding, I assume there would be little to no actual movement of the piston?? Making this an ideal method for setups such as mine where the calipers are mounted at angles other than which they were designed so they need to be removed from the discs to get the bleed nipple at the top?
Any pressure bleeding method would require some sort of spacer the same thickness as the disc to hold the piston in place since in some way or another your applying pressure to the whole system before opening the bleed nipple.
At least I think my logic here is correct..now time to go make a modified juice bottle and take the vacuum cleaner out to the garage before the mrs sees what I'm upto
