Safari Rear springs into rear of WD21 Terrano
- stovanovich
I read something on here a while back about putting Safari rear springs into a Terrano, but can't seem to find it again. The Question I have is that surely they are not just a simple take out the old ones and pop in the new ones? The Safari springs are a wider diameter than Terrano ones after all so if anyone has any knowledge on the subject, I will be very keen to hear it.
Te Rino
"Hubs In, Caps Off"
"Hubs In, Caps Off"
- passengerpete
Re: Safari Rear springs into rear of WD21 Terrano
you will need to shift ya std shock mounts so they don't foul on springs and make the lower spring perch bigger to take the springs by the time ya have done that its most likey cheeper to get some terrano lift springs.
Just done a JGC spring swap on my terrano, works a treat and got em for 60 off trade me, the guy has more too if u wana go that way
Built not brought
For4byfour
- Driver/Navigator
chop wrote:Just done a JGC spring swap on my terrano, works a treat and got em for 60 off trade me, the guy has more too if u wana go that way
Is this a direct swap? Which model/year grand Cherokee did you get them from? How much lift did you get out of it? I've just re-indexed my torsion bars, as the front was super saggy so I'm guessing the rear is too
i read that you have to use cherakee FRONT springs, and they had to be from a V8.Don't know if that is gospel.
Two inch lift over stock.
Broughto91
- Stropper
Does anyone know the factory height for wd21 on 31s?
Hi there,
have done the safari rear spring swap on my build, but i have also put a safari front axle underneath the front of it.
Did it only to keep things easy to upgrade i.e buy a whole saf lift kit rather than mismatching bits and pieces. there is a fair bit involved, cheaper to buy a a new pair of springs for the hassle.
