3 are now sold and I have 3 left.
$70+freight each. Get them while they last
Moderator: Vendors
Big wrote:Shyte Tom you must be rolling in it now..![]()
lax2wlg wrote:Good product for those wanting to keep the traditional bushed idler arm and will definitely stop it bending.![]()
Just a heads up, there were 2x different types of idler used in the WD21 with very slightly different mounting bolt hole locations. May pay to leave the three mounting holes for the customer to drill?
Although, Sometimes its confusing because the shaft may already be bent very slightly (invisible to the eye), throwing off the mounting hole location again. Even worn out bushes are enough throw it off. So it may be safer to install a new idler arm while you're at it.
