R200 head with ring rear C200 lsd with out ring gear
Now I have a C200 lsd that will take R200 axels
I will post more photos up when I have cleaned all the parts and put the diff back together
slide wrote:Did you find they both had 31 (31? from memory- its been a while) spline spider gears?
Crash bandicoot wrote:question....if the splines are the same and it fits the r200 housing...why not just use a r200 LSD?
lax2wlg wrote:slide wrote:Did you find they both had 31 (31? from memory- its been a while) spline spider gears?
29 inner/28 outer
lax2wlg wrote:Crash bandicoot wrote:question....if the splines are the same and it fits the r200 housing...why not just use a r200 LSD?
Cause most of the R200s were a viscous LSD which is shitbox offroad. Whereas we want the clutch pack type.
