Assembled gbox with replacement cluster, fitted up with new release bearing. Found clutch slave cylinder had lost its piston while sitting in the barn for 3 months...
, went to bled after replacement fitted and its seems the master clutch cylinder is stuck now too....
Cleaned out t/fer case and will fit up tomorrow with cross member, fit all bits the that are hanging down and then replace pinion seals in both diffs, refit center bearings and drive shafts. Fit extractors and drive home to fit rest of exhaust up. Then after morning tea....
Sunday was a mess, spent way longer in the pit sorting $#!& out, still no go, now starter motor has jammed and clutch wont bleed out
Still good things take time Im told...sigh
