As title suggests i am looking at putting a manual gearbox from a qd32 d22 navara into my 93 terrano.
Is this a simple bolt in option? or does it require some modifying?
Have been told the bell housing will bolt up just not sure on the rest as its a bigger gearbox.
Any advice would be great
Thanks
d22 navara gearbox into d21 Terrano
oljamesyboy
Re: d22 navara gearbox into d21 Terrano
Theres a plently posted on here, I think Lax2wlg started a thread- should show up in searches
Not a 'bolt-in' procedure, but easy enough for someone with a mechanical mind.
Crossmember doesn't bolt in and will need redrilling to make work.
Driveshafts; Front will stretch the length, Rear may be too long.
Wiring doesn't plug in, but can easily be re-wired.
Bellhousing is compatible, I think even same length bolts.
Have a look for that other thread
Nath
Nath
