3rd and 4th January
3rd and 4th January
Broke my pitman arm on my mitsi, got out of the river with cable ties and a ratchet strap
- Crash bandicoot
Re: 3rd and 4th January
are we playing trumps?. lol
Ill raise you a detatched front left. on the up side i've been waiting for a reason to SAS it.
tore out the steering and even damaged the calmini upper A arm and bent the shock..I suspect the A arm wasn't going to last too long anyway looking at that.
Nasty! I just found there was only one bolt left in the top LH balljoint , and I think I know why i have a knocking cv joint
Well my weekend was a tad different but we had a new baby
good on you wifey
- catalystracing
hamishh wrote:Well my weekend was a tad different but we had a new baby![]()
good on you wifey
Congrats
went for a cruise. out mangaweka/taihape ways.
attempted kaweka rd but got a bit confused about the direction and the mrs wasn't happy about where I was thinking to go (didn't have maps on me) so turned back. turns out I was going the right way. hahah
then cruised up ridge rd south.
jokers that live at the end of ridge rd reckoned there was an impassable slip but i didn't see it!
nice 2wd road at this time of year. didn't even need to put me jandals on to open the gates that the mrs couldn't.
Did this
And run a big end
And run a big end
sibainmud wrote:Did this![]()
And run a big end
looks like wire loop tattoo?
Bit of slide hammer time and that will pull out!
wopass wrote:sibainmud wrote:Did this![]()
And run a big end
New area at the palace.......called The Bemuda Triangle, made 2 windows just disappear. Shame it's due for felling this week
Mattman wrote:Bit of slide hammer time and that will pull out!
Best part is the old spare wheel carrier nuts are there still. Nothing a chain and a tractor can't fix
gave up on removing main pulley on the safari,brought a kettle for the truck, so there one in there when we want one, instead of did you , thought you did ,
