Pushing out a seized brake piston
Heath
Post by Heath »
Had a sticky brake piston in the calipers I am rebuilding. Tried everything heat etc.
Surfed the net and found a method using grease gun to presurise the caliper and push the piston out. After another hour of mucking around I figured other than spending money and someone else doing it I would give it a crack.
BUGGER ME it worked. Real slow but simple as pie. Just messy and used a bit of grease to do it. So another problem resolved.
Google "seized brake piston grease gun method" for how to do it.
Now I just need to get some new pistons and seals etc. Might give rare spares and Gasson motors a ring (and safe r brakes too) and see what they have.
johnny262
Re: Pushing out a seized brake piston
Post by johnny262 »
Yeah mate good old school trick, if your really lucky theyll blow out with an air gun :mrgreen:
aroma
Post by aroma »
also try undercar just before sockburn overbridge
Big
Post by Big »
overnight wd40 around piston then blow it out..
Heath
Post by Heath »
Tried soaking for 3 days, heating, tapping with hammer, hitting with hammer harder. More heat and crc, compressed air (worked for other one) more tapping and finally the grease gun method.
mercutio
Post by mercutio »
track adjusters on diggers use grease to hold the tension
my 4wd is not a truck
Mehrts
Post by Mehrts »
Handy tip to know as I'm about to tackle my calipers in the next couple of weeks.
Toyhatsu Bitsalux
Mattman
Post by Mattman »
Also works on spigot bearings.
wjw
Post by wjw »
johnny262 wrote:Yeah mate good old school trick, if your really lucky theyll blow out with an air gun :mrgreen:
First time I didnt wrap it, its amazing how fast they fly across the workshop :-D
Who knew Prados could fly?
tonyl
Stropper
Post by tonyl »
or keep pumping the brake pedal with the caliper hanging in a bucket before removing the brake hose
nivaman
Post by nivaman »
Could use bread as well, I use bread on spigot bearings, much less messy than grease.
Return to “Tool Shed”
