http://www.trademe.co.nz/Browse/Listing ... 76&ed=true
Suzuki SJ 410
Engine
Size 970cc
Bore/stroke 65.5 x 72mm
Compression ratio 8.8 : 1
Valve gear OHC,belt drive
Max power 45 bhp at 5,500 rpm
Max torque 54 lb/ft at 3,000 rpm
Fuel type Unleaded petrol
Carburettor Single-choke
Mikuni-Solex
Fuel pump Mechanical
Battery 35 AH
Alternator 35 A
transmission
Gearbox 4-speed manual
Main Ratios1 Top = 1.0
1 3rd = 1.42
1 2nd = 1.95
1 1st = 3.14
1 1
High Ratio 1.58
Low Ratio 2.51
Final Drive 4.11
Suspension
Front
-Springs Semi-elliptic
-Dampers Telescopic
Rear
-Dampers Telescopic
Steering
Type Recirculating ball
Wheel diameter 15.5 inch
Turns-lock to lock 3.4
Brakes
Brakes Hydraulic, dual circuit
split front/rear
Front Disc
Rear Drum
Servo No
Parking Drum on propshaft
Wheels
Type Spoked steel
Rim width 5.5 inches
Tyres Radial 195SR-15
Equipment
Windscren wipers 2-speed + intermittent
Interior heater Water valve
Radio AM fm cassette
Digital Clock No
Seat Upholstery tan leather
Floor covering snap in vinal
Body moulding Yes
Spare wheel cover yes
Spare wheel lock No
Passenger door mirror Yes
Lamp Guards No
Underbody protection Galvanised steel,
1 vinyl sealant
Zuki 410
Very original condition, has no major rust around the usual sj target areas, (windows sills doors) but has got a few small surface rust patches where paint has been scratches off, and a few minor dents slightly fading paint on roof etc but nothing unusual.. body generally in good condition for its age.
only mods really are tow bar & stereo with quad speakers added “surround soundâ€
