Hi I am looking at buying a 92 Hilux with a 3.8 litre Holden v6 in it. Truck is absolutely immaculate never been off road.
does anybody have any experience with this conversion i.e. what they go like off road etc.. cheers
Advice on 3.8 v6 hilux
- Driver/Navigator
Re: Advice on 3.8 v6 hilux
What engine box combo is currently in it?
- Driver/Navigator
Holden 3.8 I believe it was originally in a 96 commodore with the Holden auto and the Hilux transfer professionally installed
- Driver/Navigator
Any idea what shes worth?
Last edited by 93beachbasher on Thu Feb 19, 2015 8:15 pm, edited 3 times in total.
We run a 3.8 matched to a TH700 auto and Land Cruiser split transfer-case in my mates winch challenge truck... Runs sweet ...
If you plan to off road it you need to stop water getting into the crank angle sensor plug... We used dielectric grease on the plug and wires....
It has also had the ecu chip tweaked and removed the knock sensor input... The sensor breaks down after a while and will send erroneous signals to the ecu and cut fuel or stop it running full stop. And the fuel map changing ....And the rev limiter removed (probably not wise for a general truck) ahhahahaha
- KIWI_TERRANO
That the 2 door one on trademe?
- Driver/Navigator
yea thats the one
Last edited by 93beachbasher on Fri Feb 20, 2015 4:03 pm, edited 2 times in total.
In short, if its a good conversion, you can't go wrong
If you plan to wheel it you would want to get a custom rear pick up sump made as these starv of oil when on crazy angles for lengths of time.
- Driver/Navigator
thanks
93beachbasher wrote:Any idea what shes worth?
less than half what they are asking its not worth anywhere near the $17,000 they are hoping to get for it
