Hi all,
I am interested in what EGT's you are getting with your 1KZ's? I have a 1996 KZN185 with a 2.5 straight through exhaust pushing 33's, plus a roof cage/lightbar/awning etc. On a normal day (ie: just me in the truck and no gear), my EGT's are as follows.
NOTE: My temp sensor is PRE-TURBO and degress CELSIUS.
50km/h = 350 deg
60 km/h = 400 deg
100 km/h= 550 deg
Are these normal? Very interested to hear
What EGT's are you getting? (1KZ)
Wild_South
1997 Toyota Surf KZN185 Intercooled, Silver/Grey, 2" Suspension Lift, 285/75/r16 Hercules Terra Trac D/T, 16x8 ROH Black Track Steelies, Roof Cage, 42" LED Light Bar, Limb Risers, Snorkel, Auber Gauges, Thicker Core Radiator, MCC Winch Bar
Re: What EGT's are you getting? (1KZ)
Wild_South wrote:Hi all,
50km/h = 350 deg
60 km/h = 400 deg
100 km/h= 550 deg
how is the pre turbo done?
temps at cruise are fairly meaningless as everyones loads and idea of flat road are all different.
what really matters is temp at full noise max load (ie foot to the floor going hard up a long hill)
- floatingkiwi
Preturbo for me:
99 intercooled
100km/Hr 380 degC. Foot flat max is about 720DegC in third.
I have mounted mine where the 4 cylinders come together into the downpipe to the turbo. Took the shield off and drilled straight down. Plenty of meat to do a 1/8" npt tap.
99 intercooled
1999 KZN185W SSRG TJM T-15 Bar, Tigerz11 2speed winch, 2" EFS sus lift, 265-75R16 Engine guardian. Auberins EGT. LED light strips. weathertech cargo liner. Safari Snorkle SS145HF. Prado rad. Front and rear E-locker.
