Just cooked the engine on mamaku.
Is it typically just head gasket or more?
Overheating a td42
Overheating a td42
- Crash bandicoot
Re: Overheating a td42
Depends how bad... what caused it to get hot. Worst case scenario cracked liner.
Head check would be my first port of call being a straight six i wouldnt be surprised if its a banana. No use puttin a new gasket on there if the heads not true anymore you,ll just be doing it again in a few months.
Mud n rad also blocked air filter. And big long incline.
Runs but blowing white, no water in oil, cracked each injector , no 2 not doing much. Will pull head off tomorrow
