lifting
4x4man
lifting
Post by 4x4man »
just about to put a 2inch lift on my ute
just wondering how difficult it is to do it yourself??
thanks
stovanovich
Re: lifting
Post by stovanovich »
Why exactly are you wanting to lift?
What sort of lift, regardless though it's always easier & safer with an extra pair of hands.
Te Rino
"Hubs In, Caps Off"
4x4man
Re: lifting
Post by 4x4man »
um i am putting a 2inch body lift in an old l200
4x4man
Re: lifting
Post by 4x4man »
hello just finished putting the body lift kit on and am having problems changeing gears and putting into 4wd and 2wd ???can any one help me ???
thanks
zukmeista
Re: lifting
Post by zukmeista »
Gear levers will be hitting the body or shifter boots, remove them and move the levers into the various positions to see where. To fix you can either cut offending areas or bend the levers.
4x4man
Re: lifting
Post by 4x4man »
okay thanks do u not have to worry about lifting up the gearbox??thank
zukmeista
Re: lifting
Post by zukmeista »
You could but that would mess with the driveshaft angles and may cause vibrations.
4x4man
Re: lifting
Post by 4x4man »
also when pushing down the clutch it makes a very horrible sound???
zukmeista
Re: lifting
Post by zukmeista »
Probably a stuffed clutch release or spigot bearing, gearbox or motor out job to replace but bearing itself shouldn't cost too much. Probably best to replace clutch and machine flywheel at the same time depending on clutch condition.
cornflake
Re: lifting
Post by cornflake »
is it hydro clutch or cable
4x4man
Re: lifting
Post by 4x4man »
pretty sure its cable but dont worry think i got it fixed now ???
also does anyone know if hilux bars would fit onto an l200?
4x4man
Re: lifting
Post by 4x4man »
also once i have put the lift on will i be able to get through warrent and reg all right ???
thanks
zukmeista
Re: lifting
Post by zukmeista »
You are legally required to have a cert for bodylift to get a WOF. However there are probably places that will pass it without cert.
4x4man
Re: lifting
Post by 4x4man »
thanks but what if they do notice ????
derk
Re: lifting
Post by derk »
if they do notice they either A. give you a wof anyway and don't worry about it or B. fail your vehicle and send you around the corner to see the lvvta certifier guy to lighten your pockets a bit and give you the compliance you need to pass a wof :D
4x4man
Re: lifting
Post by 4x4man »
thanks
4x4man
Re: lifting
Post by 4x4man »
also wondering how much it would cost to put a rear diff locker in ???
mudsurfv6
Re: lifting
Post by mudsurfv6 »
4x4man wrote:also wondering how much it would cost to put a rear diff locker in ???
depends how much you want to spend and what your using the vehicle for.
auto lockers start at $400 + fitting, few manual lockers, up to 2k+ plus fitting for eaton harrop E-locker.
depends what is made for your vehicle.
they all have pros and cons.
Andrew 0272226292.
