Hi I've got a problem with the winch and am trying to work out what's going on. We used it quite a bit last weekend without any problems. I went to wind the excess cable in yesterday while fixing things and the winch won't go at all. The solenoids click but no motor action. Does anyone know what the problem may be or what else I can check? I have checked all electrical connections that I can find.
TIA
Nigel
Winch not going :(
Hi no I haven't checked with a voltmeter. Should I check the power flowing into the winch motor? They just click once when I push either in or out button. I don't know what they used to sound like because I've never heard them click over the noise of the winch itself. It's a trademe Chinese winch. 24V 9000lb. My batteries are 2 weeks old.
Hi nigelb, I had this problem with my chinese 12v winch and it was the earth brushes had rusted between brush mounting plate and main body if that makes sense,solenoids would work and power would get to winch but no go,just drilled out the rivets that hold the brushs in cleaned them up put small stainless nuts and bolts to hold them in and away it went,hope this helps
hi nigelb, i have had a similar problem, solonoids went etc but winch was dead. pulled it apart and turned out to be a brake in the brushes circut where it exited the body to one of the terminals....
best bet would be to pull it apart and have a nosey.... youd save some money not taking it to someone.
theres not really a lot inside
just a thought
