power wound new rope on heaps of room on new drum
sublimenz wrote:Cleaning up garage after throwing my toys then fitting standard diff into challenger seeing as my locker was rooted.
Then all going well respray the underside of the truck then hopefully just wheel aligment left to do.
Mehrts wrote:Jack up the rear wheels and engage locker. While turning one wheel by hand: If both wheels spin same way = locked, opposite ways = unlocked. Compressor starting often indicates there's an air leak somewhere in the system.
coxsy wrote:Wayne says ,check the nylon pipes ,has leaked there before, drain the oil out of the rear to see if water in there ,shouldn't be but check.
derk wrote:ya going to need something under the front of that thing that you can fit a set of longfields intothat factory ifs stuff is only designed for softroading not snotting around with your boot up it sporting a set of simexes
Crash bandicoot wrote:Went out for a play today, totally obliterated the front right inner and outer CV's
lax2wlg wrote:Crash bandicoot wrote:Went out for a play today, totally obliterated the front right inner and outer CV's
Ya could upgrade to the 28 spline V6 axles which have a ball/cage inner joint too. The tripod joints don't seem to tolerate angles as well as the ball/cage.
The dimensions for the bell/cage/stub shaft on this unit are all exactly the same as the C200 live axle from the MK Patrol. In fact I'm pretty sure the entire outer joint is the same item aside from the notch where the CV boot slides on to clamp down. The inner ball/cage joint uses the same cage/bearing race as the outer.
Only thing is you need to change the needle bearings in the spindles too, otherwise they won't fit through the hole.
