Raising the Terrano
Henryford666
- Winch master
Raising the Terrano
Greeting !!! So I want to raise up my Terrano It has 31's on at the moment I'd like to go little bigger in tyres and lift it. What's the best ideas Cheers for you thought s Matt
- Crash bandicoot
Re: Raising the Terrano
read either this thread...
http://www.offroadexpress.kiwi/Forums/viewtopic.php?t=34933
or this thread...
http://www.offroadexpress.kiwi/Forums/viewtopic.php?t=43065
As you will need to deal to the steering linkages before raising it or you will spend the rest of your day's replacing bent tie rod ends.
or this thread...
2" lift springs rear easy. Readily available. Using cobras in mine, very stiff however.
Front torsion bars. wind them up a bit. easy (usually need re-indexing too). be prepared for steering problems.
Body lift kits, make yourself or buy, readily available on trademe. easy.
Can fit 32s easy, 33s (thats 10.5 wide not 12.5) fit with a little guard trim i believe. rim size 8" wide, offset around -12 to - 20mm i believe. Im running 32x11.5x15 maxxis bighorns on an 8" wide rim with -12 offset. only mangled the guard on the front left when I bent the steering idler.
I repeat, the steering is always bending and breaking. have a good read up on old threads on here.
Good luck out there.
Henryford666
- Winch master
Thanks guys. Appreciate your input
If you want to do it on the cheap Izusu UB69 front shocks and rear springs fit and are longer than the terrano ones.
I used them along with monroe airshocks.
The izusu rear springs give an immediate 30mm lift in the rear straight away then just wind the torsion bars up.
Hope that helps.
Hope that helps.
watch the tyre size you get away with larger tyres running around on the road but once offroad you'll find you'll suffer from "bent steering syndrome" and it starts wearing thin after a while
idler braces and tierod upgrades/modificatins improve things but its still relatively weak steering setup for offroad
there's tons of stuff about steering improvements on the net it'll keep you busy for a while reading through it all
derk wrote:watch the tyre size you get away with larger tyres running around on the road but once offroad you'll find you'll suffer from "bent steering syndrome" and it starts wearing thin after a whileidler braces and tierod upgrades/modificatins improve things but its still relatively weak steering setup for offroad
Thats not true. Its just like your solid axle Hilux, if you are going to wheel it aggressively, you are going to need to upgrade the steering
Just gotta get creative
Dual steering boxes (idler delete) + 2wd steering mod with my 4140 adjusters = problem solved. 33s and front locker, booting it up rocky ledges easy. Super reliable and strong, nothing to bend. Fixes geometry problems that cause the factory setup to bend when lifted.
are you ever going to market those adjusters,Lax?
sounds like that terrano steering is pretty bulletproof and robust mate you might as well lift her up and throw the biggest set of tyres you can find onto it and ignore all the rest of that rubbish about weak steering all over the net she'll be ready for as much hardcore shit you can throw at it
derk wrote:sounds like that terrano steering is pretty bulletproof and robust mate you might as well lift her up and throw the biggest set of tyres you can find onto it and ignore all the rest of that rubbish about weak steering all over the net she'll be ready for as much hardcore shit you can throw at it
Why do you have to act like a spoilt 5 year old when someone has a different opinion? He never disagreed that it was weak in standard form, just said that it is possible to upgrade it to handle bigger tyres. Some might compare it to upgrading landy diffs but that's a whole 'nother argument
- Crash bandicoot
Not been here in months......and............nothing has changed!
So much more fun shit to be doing/chicks to be doing than arguing on the internet.
Nothing wrong with good information that other people can benefit from though
