130 v 185 drum brake size
mudsurfv6
Post by mudsurfv6 »
does anyone know if the rear drum brakes on 130 and 185 surfs are the same external size?
because I have just been told 185 calipers won't fit on 130 hubs ( which I was planning on doing for sas) which means I use 130/hilux calipers which means 15 inch rims will fit on front. looks like heaps of room around drums on rear. if 15s fit rear I can use 15 inch rims which means a lot easier to find second hand rims and tyres. :)
if that's the case I will have some factory 80 series alloys and staun internal beadlocks (new) for sale. :roll:
Andrew 0272226292.
mudlva
Re: 130 v 185 drum brake size
Post by mudlva »
Cant remember what the dia is but 185 run two differant disk sizes
mudsurfv6
Post by mudsurfv6 »
mudlva wrote:but 185 run two differant disk sizes
but would the 185 caliper from either size 185 disc fit on a 130 hub?
its the rear drum external measurement I'm after, is 130 and 185 the same size?
Andrew 0272226292.
mudlva
Post by mudlva »
Sorry my bad. Missed the rear part of your question.
I can measure a 185 drum that ive got in shed. But will not be till tomorrow
Return to “Toyota”
