Hilux gear stick rotates
braydenh28
Post by braydenh28 »
Hi there I am writing this post as I need some help as my gear stick started playing up and became very loose I still managed to drive it by turning the gear stick to hold it tight when changing gears. But now the whole stick has come out!! Is this a serious problem? I have taking acouple of photos and hope someone can provide me with information on how to fix it... Cheers any help will be much appreciated.
tweake
Re: Hilux gear stick rotates
Post by tweake »
well thats odd, both bush and socket are gone (theres often bits left) and the pins are gone.
heavy duty bushes from marlin tho a few locals do sell them. not sure about the pins, might have to make something or find a new housing.
braydenh28
Oh that dose not sound good. The bushings wouldn't be a problem. Do the pins hold the stick in? Ha wounded how they would of fell out?
Smurf
Post by Smurf »
Yep, as Tweake stated there should be two pins in the housing that locate the lever and also a bush on ball at the end of the lever and a second bush that the lager cup rotates on.
http://www.trademe.co.nz/motors/car-par ... 301681.htm
The pins have most likely snapped off due to there not being any bushes and the pins being hit by the lever when you change gears, may pay to drop your gearbox oil and see what comes out for peace of mind
tweake
Post by tweake »
the pins stop the stick from turning around. usually very hard to get the pins out.
maybe you can thread the housing and screw some bolts in.
braydenh28
Smurf wrote:Yep, as Tweake stated there should be two pins in the housing that locate the lever and also a bush on ball at the end of the lever and a second bush that the lager cup rotates on.
Cheers mate I just brought the bushing in that link... Do uno what the other bushing I need is called mate? So I can look it up and order
braydenh28
tweake wrote:the pins stop the stick from turning around. usually very hard to get the pins out.
Ok I see. Cheers for the info... Is it not possable to buy these pins?
Smurf
Post by Smurf »
https://www.youtube.com/watch?v=m0ie37ykAJQ
start of this video shows you what should be in there, except the bottom bush.
The other is referred to as a shifter seat bush, which is mentioned in the trade me ad, so they should also have them.
https://www.marlincrawler.com/transmiss ... duty-seats
Smurf
Post by Smurf »
looking at your photo a bit closer it almost looks like at least one pin has come free as there appears to be a hole in the side of the housing on the side at the bottom of the picture . they would fall outwards not in if they came loose.
Edit, also see that NZAD stock the seat bushes.
Not sure but I think this is the one you require
catalystracing
Post by catalystracing »
I did my gearbox lately and just got the bushes from the Toyota dealer, weren't a bad price. I didnt need pins tho.
klompy
Post by klompy »
Just get a good second hand one and bolt it on.
braydenh28
Good second hand what kolmpy? Dose the hole housing unbolt
Im a Tumor
Post by Im a Tumor »
yes that top housing unbolts. 4 bolts and it comes off
Return to “Tool Shed”
