hey all, just wondering what gearbox combos are good to run behind a 1uz in a hilux? auto or manual, PTO for winch etc. will be aiming to use the truck in winch challenges etc so whatever can handle hard abuse the better.
1uz gearbox options
Re: 1uz gearbox options
get an auto and manualise it, with the 70 series transfer option just need find the factory adaptor and it all bolts up like factory.. or get a LJ7* auto and swap some small bits and ya away running.. very easy..
how easy is it to manualise one? i do like that idea. iv seen a couple of pepole use the original 1uz auto box and modify a transfer case to fit on the back so was thinking that could be the go as iv got a couple lying around the shed.
Real easy to manualize,2 relays and a couple diodes and I had mine done in a arvo..other option is buy a shifter from RADdesigns in the states or similar
This is my tutorial on manualising the auto.. I set mine up to use the shifter..
Bit more work than just some diodes...
viewtopic.php?f=17&t=29063&hilit=a340+manual
awesome thanks guys its a bit clearer now. its good theyre cheap as hell to convert too which is a big plus
