Have got some more bushes.
For previous thread on these see http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=67&t=31587
Got some 48702-60050 which are listed as 80 series front arm bushes. These go at the axle end of the arm, 4 are required for a complete set. Can do these for $55 each incl post GOT PLENTY NOW
Dimensions are
ID 16mm, Length 50mm, OD 60mm, Length 40mm
So these also fit the axle end of the KZJ and LJ TRAILING arms plus they fit the axle end of the KZJ LEADING arms on the front.
ALSO my understanding is that they fit the axle end of the Nissan Safari Front Leading Arms.
Last time some 48702-60060 which are listed as rear arm bushes for post 1990 KZJ's and LJ's These where $65 each incl post Decided not to get any of these as they are essentially the same as the 80 Series ones but $10 dearer. So for your LJ and KZJ use the 80 Series ones.
Much cheaper than the $150 to $200 each I was quoted by Toyota.
Also got some of the bushes that go in the Chassis end of the 80 Series Leading arms
Part no is; Bush, Lower Arm 48061-60010
Dimensions are
ID 18mm, Length 60mm, OD 54mm, Length 40.5mm
These are $65 each including post.
Plus got some 80 series rear upper and lower control arm bushes.
Bush Sub Assy, Upper Control Arm 48702-60031
Dimensions are
ID 18mm, Length 60mm, OD 50mm, Length 45mm
These are $55 each including post.
Bush Sub Assy, Lower Control Arm 48702-60040
Dimensions are
ID 18mm, Length 60mm, OD 55mm, Length 45mm
Also some KZJ78 or LJ7? Leading and Trailing arm Chassis End Bushes, these are different to the 80 Series ones.
Part no is; Bush Sub Assy, Leading Arm No2 48061-60020
All are genuine Toyota parts.
PM me if interested.
Tim
