R50 workshop manual
- Winch master
R50 workshop manual
Does anyone know where to get a workshop manual for an r50 terrano from? Preferably with the diesel motors?
Re: R50 workshop manual
I havent managed to find one either, the V6 one is pretty easy to find but not really useful when you generally want the manual mostly for the engine section.
Mines a ZD30 so I could possibly find a Patrol manual tho I havent really looked. The R50 ZD30 is pretty much the same as the Patrol setup, but not the Navara setup.
- Crash bandicoot
Still cant locate one which covers any of the diesel engine models that we commonly get here.
Pathfinder ones only cover VG33 and VQ35, Patrol ones only cover TB42, TD42, RB30, RD28E
Havent downloaded the R20 but theres a chance that may cover the TD27E
If anyone knows of one that covers R50 ZD30DDti would be hugely appreciated, or even a Patrol one that covers ZD30 seems to be identical to the Terrano setup but not the Navara ZD30
- Crash bandicoot
Get the R20 one then as the 2000 onwards mistrals/terrano 2's had the zd30ddti engine and i have seen that in the manual. along with the TD27ETI.
but the eti apart from its computer controlled pump and location of the tach/ crank /tps senders and the location of the vacuum pump are not much different to the TD27-T
