Kzn185 auto issues
brakes-shocks-lockers-etc
imsohi
Kzn185 auto issues
Post by imsohi »
Having some problems finding a diagnostic code pulled from the truck OD light flashes 3 then 8 so Code 38 (Tripple Checked this). Auto has no issues that i can tell when driving only when you get to 75 deg water temp the o/d light starts flashing, have done a fair bit of reading and usually is the solenoids but there codes are 42 or 61-65 so im a bit stumped cant find a fault code 38.
anyone struck this before
Cheers Leigh
QUADRACER
Re: Kzn185 auto issues
Post by QUADRACER »
Temp sender on trans , either faulty or bad connection .
Had Same issue.
Same as Lexus sender.
imsohi
Post by imsohi »
Cheers Bob
