I just bought a 1994 jeep xj Cherokee my second one but shes a bit run down for the warrant I need
* All front sway bar bushs to be replaced
* Left hand engine Mount to be replaced
* Both front axle outer UJ worn needs replacing
* Rear propshalf UJ and front prop, rear UJ worn
* All balljoints worn and need replacing
* Right hand rear bump stop replaced
* Rear leafs rear bushs worn
* Rear brake pipe
that's all the harder stuff there is more
Im going to be doing all the work myself.
so what I was thinking of was getting a whole bush kit, do every bush there is and do both engine mounts is just wondering is there a place I can get all this from and whats the cheapest? usa repco any suggstions? I will be getting a lift kit at a later date just need to get it road legel first.
thanks for any help you got
ash
Hello need parts!
detox
- Winch master
Re: Hello need parts!
http://www.ebay.com/itm/4-FRONT-LOWER-U ... 17&vxp=mtr
http://www.ebay.com/itm/2-FRONT-SWAY-BA ... e0&vxp=mtr
free shipping think they would do the job?
yeti
- Bruiser
get a lot of that shit here now .....got last ball joints here
http://www.extremeautomotive.co.nz/
http://www.offroadspecialties.co.nz/
make a few calls in the morning ....
v8 tj...luvs the gas......
detox
- Winch master
80 bucks for all 4 thou? how much did you pay doing a pre trade building course and working 3 days a week so money is tight
detox
- Winch master
any idea what axle this is?
You do not have the required permissions to view the files attached to this post.
lax2wlg
Its either a Dana 35c or a Chrysler 8.25.
Hard to tell from the picture.
If the housing has a flat bottom its a C8.25
detox
- Winch master
dana 35 c I think
yeti
- Bruiser
Turdyfive .... Jeep and worried about cost ... Yeah na fella ....
detox
- Winch master
so I cant find the u joints I need they say there for a dana 30 dana 44 no dana 35 will they fit any way
I know I need 2 for the front axle
and 2 for the drive shaft
detox
- Winch master
DANA HOLDING CORP Part # 51309X Spicer Greasable Universal Joint
Rear Shaft Front and Rear Joints; RWD; Body code XJ; Compact; Diagram Location: 1,2; Diagram: A; w/inside snap rings
Rear Shaft Front and Rear Joints; 4WD; Body code XJ; 7290 Series; Compact; Diagram Location: 5,6; Diagram: I; w/ 4 inside snap rings B
$18.73 $37.46
DANA HOLDING CORP Part # 5760X Spicer SPL Lube For Life Non-Greasable Universal Joint
Front Axle at Wheels; 4WD; Body code XJ; COMPACT; diagram location: 1; diagram: I; w/ 1.188 Brg. cup dia.; Wheel Joint B
$22.79 $45.58
will this work o_O 2 of each
$18.73 $37.46
$22.79 $45.58
